Solved by arshadmirza786. Go to Solution.
I solved this problem on my system by going here
and selecting the Printer series from the list and then operating system on next page.
I downloaded "HP Designjet 500 and 510 HP-GL/2 and HP RTL 64-bit driver"
Then force windows 8.1 to install the driver, it kept telling me that the driver was up to date, but make it install.-
Turn plotter on go to device manager printers, right click > update driver > browse my computer > let me pick form a list.
After this it worked for me.
Hope this helps someone else.
Sorry these DRIVERs are for HP DESIGNJET 500 hp-gl/2 and plus
where as I have a simple HP DESIGNJET 500 without and extended features so these DRIVERS can not support my device
Sorry for inconvence
@ arshadmirza786
I also "have a simple HP DESIGNJET 500 without and extended features" which is quite old now and it worked for me, so these DRIVERS Should support your device. But you have to try it first before it works. I selected the first one on the list in your image but I think you need the second one.
Thank you for all the friends how participated in this post
I have just change my mind and downloaded the "hpdj500wx64pclen" from HP.COM instead of hpgl/2
and it has solved my problem
thanks again for all
I had this problem too, but with the hpdj500... driver it couldn´t be resolved, so I find this link and it is running fine now.
HPDesignJet4500PrinterSeries x64 driver.
http://www.helpjet.net/files-HP-Designjet-4000.html#ADriver
I hope it help.
Hello there,
May I ask you where did you find Win8 drivers for that DesignJet 800 ? Because I'm not even able to connect the **** thing to the comptuers (here under Win 8.1 x64)
Even if I'm a bit out of topic... thanks by advance.
JBR.
My Windows 8.1 does not have those screens and runing msconfig to get there doesn't help.
Does it help to change to the HP or Windows driver (which are probably the same)?
Cheers
John Schwartz
I guess we are stuck I've tried emailing HP with issue but no anser I guess we are stuck with old plotter.
I switched to the new HP driver for my 500 and after trying them all and IT WORKED (WHY) ?
Can't wait for all packages of autocad to be on a mac.
Scenario. Plotter HP 500 monov24 LPT printer, Win 8.1, Autocad 2015, installed basic driver (non HPGL) driver & I am able to print documents & PDF but can't plot through AutoCAD 2015. It asks for HPGL driver.
When I installed HPGL driver, the plotter screen shows error processing the print job. I have 5 PCs with AutoCAD 2015 and win 8.1 combination. All are able to print the docs but the only problem is Plot command via Acad 2015.
Solution.
I downloaded printershare tool from printershare.com,
I kept the basic (non HPGL) driver on the PC where plotter is connected via LPT and installed printershare on it and shared the plotter via printershare.
I installed printershare on all other PCs and searched for shared printer via printershare tool.
I opened Acad 2015 and clicked Plot and selected printershare from printer list and gave a plot command.
Hurray it printed successfully.
You my friend are brilliant. Used the same file you recommended. Works excellent. Running Windows 10, do not ask me why, and current version.....thank you.
I do have some problems still with 500, so switch to plot as pdf then open in acrobat of other pdf program and plot from there.
There is another way to solve that problem.
You can try using you Router Print Server (if you have ofc.)
I have a TPLink router.
Despite the fact that in the list of supported printers HP 500ps 42" is not included - its working.
So is there a definitive answer to this problem?
Same issue here - New computer system on our office server. windows 10 installed and trying to print to our old HP Desgnjet 500 is not working.
Every other program (except AutoCAD 2017) is printing fine.
Using the LHPGL and SHPGL generic drivers allows us to print but with screwed up margins.
At the price they charge for the Software, a driver for this most popular printer should be supplied. The HP Designjet 500 may be out of service but many small architectural firms are still using them!
