HOW TO USE THE AECTOACAD COMMAND?
Message 1 of 8
hi there
i try to use this bcoz of FOREIGN DWG FILE and i read that AECTOACAD works for this
bu i dont know how to use it
i also attached the DWG file
please help me to check it
thank you very much and i hope for anyone to answer this
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Forgive me, but what problem are you trying to solve exactly? "foriegn dwg file" means little as I look at your file, other than the fact that it appears your dimensions are all messed up because someone moved the model but forgot to turn on that layer first
Message 3 of 8
FOREIGN DWG FILE
Message 4 of 8
im sorry i forgot to attached the other file
Please check the FOREIGN DWG FILE and SECURITY CONCERN
thanks very much
Message 5 of 8
Alfred.NESWADBA
the first message tells you that this DWG file was produced on a none-Autodesk product.
It's a warning, not an error. Just run _AUDIT to make sure that the internal drawing database is ok.
The second messages gives you the info, that AutoCAD tries to load a tool (in that case ACADDOC.LSP) from a folder that is not marked as a trusted folder. And to prevent that AutoCAD then loads a virus it gives you that warning with the question if you want to load it or not.
I would not load a file ACADDOC.LSP from a download folder as long as I don't know who created that file and if I can trust it more than 100%.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 8
about security concern
i remove now
i just use OP comman then FILES tab then check TRUSTED LOCATION then specify the location of files only through browsing the folder
thanks anyway
Message 7 of 8
Alfred.NESWADBA
just one warning from my side: a downloads folder is imho always a critical folder for the first place of a virus.
So please think about that decision to add the downloads folder to the trusted paths!
- alfred -
Alfred NESWADBA
Message 8 of 8
okay no problem..
i will not do adding the folder for this is virus ^^,
thanks
