default settings have gone
Message 1 of 8
can you help me  - the drawing tools have gone funny - i cant put the curser over a line with out it darting about with in a much larger area than before -  i am unable to locate the cursor over a point as before and click on it to snap to it - i have probably changed a setting with out realsiing and cant undo it?
Replies (7)
Message 2 of 8
Bud_Schroeder_ADESK
Hi Robert,
Thanks for posting to the forums, can you tell us what product you are using when you see this? For example AutoCAD 2017. That will help us get you pointed in the right direction for help here.
Thanks and looking forward to hearing back from you on this.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Message 3 of 8
Hi, its the 2016 version
Kind regards
Message 4 of 8
Emmsleys
Hi @Anonymous,
Are you still having an issue with your AutoCAD settings?
Do you have the same issue if you log in as a different windows user?
You could always try resetting your settings to default locate the "Reset to Defaults" option, I have included a picture below on where you can find this feature as well as looking over this article. Save a copy of your custom settings if needed. Let me know if this helps.
Sarah Emmsley
Technical Support Specialist
Message 5 of 8
GrantsPirate
Could be as basic as setting SNAPMODE to off (0).
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 8
Emmsleys
@Anonymous
Following up on your question, were you able to try any of the steps suggested in this thread?
Please post back in the thread if you are still having an issue with AutoCAD I'm sure the community will be more than happy to help.
Sarah Emmsley
Message 7 of 8
Emmsleys
Along with the suggestions made in this thread you can also try the following;
  1. Reset to defaults
  2. Cursor in the Drawing AKN Article
System Variable
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Message 8 of 8
Emmsleys
@Anonymous
Following up on this thread, I haven't heard back if you were able to try the suggested steps.
Please post back in the thread if you are still having an issue with AutoCAD the community and myself will be more than happy to help.
Sarah Emmsley
