multiple sectionplanes
Message 1 of 8
Does anyone know if there is a solution to regenerate multiple sectionplanes at once?
It is a lot of work/time to regenerate about 15 sectionplanes of a large model
Replies (7)
Message 2 of 8
john.vellek
Hi @Anonymous,
I am unaware of a feature to do this but if you could send me a sample drawing I would be happy to see if I can find a solution to your regeneration issue.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 3 of 8
It is not drawing specific. I am looking for a routine to regenerate ALL sectionplanes at once (with one command)
Message 4 of 8
john.vellek
Hi marko.stout,
I apologize for not having a definitive answer for you. Can you explain in more detail what you are trying to accomplish? I understand that you have a large and complex model. You are cutting through the model with multiple sectionplanes.  From there can you describe the process you are going through?
I suspect that you are adjusting one or more features of the model and then trying to have your sections reflect the updated condition.
If my assumption is incorrect, please let me know. I have good resources on my end even though I have only limited experience personally in working with this process. I hope that I can help you to resolve your problem.
Again, if you have a representative drawing or screenshots that reflect the issue that would be helpful. Thanks for your patience.
John Vellek
Message 5 of 8
john.vellek
Good morning marko.stout,
I am checking back to see if my post helped you with your problem. Please provide additional information as requested to the post if I can assist you further.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.com
John Vellek
Message 6 of 8
John,
I am working in a huge model with solids.
In this model i have several sectionplanes;
5 horizontal level planes
4 facade planes
7 cutting section planes
 see screenshot
When i change one or more solids in the model all the sectionplanes need to update.
The action is as follows;
select a sectionplane
  rightclick and select "Generate section" and then "2D/3D block"
    In the new window select "create"
      then wait a little time to finish the command.
select a next sectionplane
etc. etc. for 16 times.
It should be easier if there was an option to tell autocad to (re)generate all sectionplanes at once.
Then i could go for a cup of coffee.
Message 7 of 8
john.vellek
Hi marko.stout,
This certainly does sound tedious. Since I am unaware of a built-in feature that would do this for you, I would like to suggest that you perhaps create a Macro with the Action Recorder. While the generation time would remain the same, it would at least automate some of the process for you.
John Vellek
Message 8 of 8
john.vellek
Hi marko.stout
I am checking back to see if my post helped you with your problem. Did you have any luck playing with a Macro to automate your task? Please add a post with your results so other Forum users can benefit.
John Vellek
