AutoCAD Forum
How to turn off trim preview?
9 REPLIES 9
Message 1 of 10
zzz144
8769 Views, 9 Replies
help - its slow and annoying...
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
in reply to: zzz144
sysvar COMMANDPREVIEW (>>>details<<<).
BTW: I have not had any performance issues with that yet. What object types are slow for previewing?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 10
zzz144
in reply to: Alfred.NESWADBA
Thanks Alfred!
its just that milisecond that makes me miss the line - especially if the lines are gray...
typically this happens on polylines that have width assigned to them...
see the attached.
i invoked trim
spacebar to select all
clicked for crossing window and it froze...
Message 4 of 10
rkmcswain
in reply to: zzz144
i invoked trim
Can't imagine why.....
Smiley Wink
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 10
in reply to: rkmcswain
i get lag when i am working on polylines on top of reference images
Message 6 of 10
ceethreedee.com
This definately happens when trimming complex 3d polylines... even mildly complex..
Civil 3D 2025 / Infraworks 2025
Win 10 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free tools for civil 3d at website below!
https://ceethreedee.com/ceethreedee-tools
Message 7 of 10
zzz144
in reply to: ceethreedee.com
Cmon AutoDesk - fix it....
Thankks!
Message 8 of 10
Alfred.NESWADBA
in reply to: zzz144
You marked the thread as solved with disabling _COMMANDPREVIEW ... isn't it solved or what should Autodesk fix?
If you think it's a bug (which I don't think as there is an option available to avoid these some milliseconds, as you reported), then send the info as support case so it can be forwarded to the development team.
- alfred -
Alfred NESWADBA
Message 9 of 10
zzz144
Alfred, I apologize - my bad - I just assumed this was a booboo without checking...
Since you are here - maybe I could bring up another one that never got resolved.
imagine you have a drawing with lots of stuff in it... lots of blocks - say 10mb file.
When I go in and edit one of the blocks and save the block edit and get out into the main drawing - the main drawing is ever so slow to respond to things... Why is that? is there a solution to it?
Message 10 of 10
hlammerts
Hi Autodesk coders,
may i bring this in as a suggestion.
Out in some lines between these Gigabytes there are allrady in AutoCAD..
if
number of items is bigger than ( lets say..: userdefined)
then
temporary turn off preview effect
it sometimes slows things down really fast. Especially trimming with 'fence'method
Kind regards
Hans
The Netherlands
https://www.cadsite.be/smf/index.php?action=dlattach;topic=6598.0;attach=4434;image
Forma Design Contest
