We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
hi,
as you trim a line.
Imad Habash
Please find this video for how to trim a hatch.
Also shown in that video that the hatch can be associative and it will also be after using TRIM on it.
- alfred -
Simple solution but it worked thanks!!!
hello sir,
if hatching by clicking objects can i trim it?
Hi and Welcome to AutoCAD Forum,
would you please post a new question ( with little details ) to get a proper help ? 🙂
Imad Habash
As far as I understand your question: yes
- alfred -
for some reason, the solution suggested doesn't work for me... What am I doing wrong?
That's impossible to say without knowing what you are doing, exactly. Can you post a screencast, or a small sample drawing containing a Hatch pattern that you are not able to Trim and the cutting edge(s) that you can't Trim it to?
A possibility: Is the Hatch pattern in question in the same or a parallel plane as the cutting edge(s)?
Thank you! This works perfectly.
