AutoCAD Forum
how to trim hatch?
9 REPLIES 9
Message 1 of 10
90759 Views, 9 Replies
how to trim hatch?
9 REPLIES 9
Message 2 of 10
imadHabash
hi,
as you trim a line.
Imad Habash
Message 3 of 10
gotphish001
You can trim the hatch but it must be non-associative to do so, I believe.
Nick DiPietro
Cad Manager/Monkey
Message 4 of 10
Alfred.NESWADBA
Please find this video for how to trim a hatch.
Also shown in that video that the hatch can be associative and it will also be after using TRIM on it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 5 of 10
in reply to: gotphish001
Simple solution but it worked thanks!!!
Message 6 of 10
in reply to: Alfred.NESWADBA
hello sir,
if  hatching by clicking objects can i trim it?
Message 7 of 10
imadHabash
Hi and Welcome to AutoCAD Forum,
would you please post a new question ( with little details ) to get a proper help ? 🙂
Imad Habash
Message 8 of 10
Alfred.NESWADBA
As far as I understand your question: yes
- alfred -
Alfred NESWADBA
Message 9 of 10
for some reason, the solution suggested doesn't work for me... What am I doing wrong?
Message 10 of 10
That's impossible to say without knowing what you are doing, exactly.  Can you post a screencast, or a small sample drawing containing a Hatch pattern that you are not able to Trim and the cutting edge(s) that you can't Trim it to?
A possibility:  Is the Hatch pattern in question in the same or a parallel plane as the cutting edge(s)?
Kent Cooper, AIA
Forma Design Contest
