How to tell OVERKILL which objects to delete?
s.proch
s.proch
Hi all,
I an struggling to understand which objects (above or below, drawn first or drawn second) does OVERKILL command actually delete. Is there a way to tell the command that I want to keep the objects that are above the others?
In my case, I am working with polylines and/or lines and they were all imported at the same time using PDF Import.
Thanks all.
cadffm
>>"which objects"
First short test, less than one minute, result is: creation order.
>>" Is there a way to tell"
No.
Sebastian
s.proch
So, because I imported them all at the same time, my polylines will always get deleted randomly. In some instances above and in other below. And there is nothing I can do about it?
cadffm
a) >>"So, because I imported them all at the same time, "
YOU imported all the same time (because it is for you one step only / one command)
but The program can not create multiple objects at the same time, all steps are linear  / in a row
and also the PDF content: Someone created the PDF and this content was also created linear  / in a row
<for example, if you plot to pdf from AutoCAD: It is the drawordner>
b) >>"my polylines will always get deleted randomly."
In your eyes it is, but technically not.
c) >>"In some instances above and in other below. "
That must be a special situation (and setting in your pdfimport). For 1:1 imported objects (like a circles) ,
the draworder and creation-order should be the same (I think).
   <It's difficult to discuss without a concrete example>
d) >>"And there is nothing I can do about it?"
I think 'No' is the right answer, but without a specific sample (pdf/dwg/(overkill setting), hard to say.
Sebastian
pendean
Community Legend
Community Legend
Short answer: the command does not allow for user input to prioritize selection.
Easy fix if you don't like the results from OVERKILL: do it manually yourself for absolute control.
HTH
s.proch
That is unfortunately not an option as I have thousands of instances.
Thank you though.
s.proch
Thank you!
