How to (successfully) convert pcp file to ctb file?
Prvoime
Message 1 of 33
Prvoime
Hello to everyone.
When exporting from Revit to AutoCAD I also get a pcp file.
I use "Add-A-Plot Style Table Wizard" to convert it to ctb file, but it doesn't convert really accurately.
First, the colors, they don't convert at all. As you can see in my little example, from Revit everything except the logo prints black. From AutoCAD everything prints in color.
OK, I can solve this manually, but is there some better way? It's not an issue with drawing that are mostly black, but could get tedious with drawings that use a lot of colors and shading, to hunt down all those colors of layers.
Second, the thickness. I deliberately set ridiculously thick lines for walls in Revit to illustrate the issue. Thickness don't translate in AutoCAD. At all.
It's clearly visible in this example, but it's worse when you don't use ridiculous values, then everything just ends up being the same thickness.
Any way to solve these issues?
Here are prints, first Revit, second AutoCAD.
Replies (32)
Message 2 of 33
pendean
Community Legend
Community Legend
Start from scratch: its quicker.
Message 3 of 33
Prvoime
Forgot to mention, when line thickness is turned on in AutoCAD itself, those thickness do seem to translate correctly.
If that can somehow help to solve it.
Message 4 of 33
RobDraw
In Revit, colors can be ignored with print settings. Making a comparison in that aspect doesn't apply.
Please explain the steps you followed to "convert" the .pcp file to a ,pcp file as you stated. That doesn't make sense.
Rob
Message 5 of 33
Prvoime
I said PCP to STB. I actually made a typo there, I need a CTB file, not STB.
Pictures above are with CTB file.
In AutoCAD start the STYLESMANAGER command.
This opens up folder with plot styles and among them there is also "Add-A-Plot Style Table Wizard".
Start it, follow the steps, it allows to select PCP file to be converted into CTB file (or STB).
But, as shown, result is far from usable.
Message 6 of 33
Prvoime
Edited the typos.
Message 7 of 33
RobDraw
If "black lines" was used to print from Revit, you may need to edit the .ctb file to reflect that setting. If you are exporting the sheet, I don't think you can account for that setting. Can you confirm?
Rob
Message 8 of 33
Prvoime
Black line were not used for printing from Revit, but i did export the sheet.
Message 9 of 33
RobDraw
How are you able to print from Revit without colors or how are you getting colors into your export?
Rob
Message 10 of 33
Prvoime
@RobDraw
Revit is "What you see if what you get" type of software. How something looks is determined by its category.
So if you want your wall lines black, 0.7mm thick, that's what you get, on screen and printed.
When exporting to dwg it automatically creates a PCP file, and objects in Revit are translated into layers based on standard you choose (AIA, ISO, some other...).
Message 11 of 33
pendean
Community Legend
Community Legend
You'd be done by now if you ..."Start from scratch: its quicker."
Message 12 of 33
RobDraw
@Prvoime wrote:
@RobDraw
No need for CADsplaining, I know how Revit works. I haven't had to export for production use in a long time so I might be a bit rusty in this aspect but not a stranger.
Let's try this again. My question is based on your first post saying that Revit prints black and you are using colors. How are you accomplishing that?
Rob
Message 13 of 33
Prvoime
Oh, I see what you mean, I didn't explain well so we misunderstood each other (not an English speaker so my sentence syntaxes might be a bit off).
When I said "the colors, they don't convert at all", I meant the fact that everything except the logo should be black doesn't convert (layer colors in converted CTB file don't get assigned black color).
Message 14 of 33
Prvoime
That's no fun 😁
Message 15 of 33
RobDraw
What are your export settings?
Rob
Message 16 of 33
Prvoime
Stock settings, what ever they are 😄 Didn't change anything there.
Message 17 of 33
RobDraw
You might want to look at them.
Rob
Message 18 of 33
Prvoime
You mean setting colors in exported DWG to "Specified in view"? Yeah, that's not a solution, I can't send out DWGs to people where all layers are in the same color.
I did some more googling, apparently it just can't be done.
Message 19 of 33
RobDraw
I'm still not clear about what you want 8r even what you have. Can't you try explaining it again? Sorry for the confusion.
Rob
Message 20 of 33
pendean
Community Legend
Community Legend
@Prvoime The part I find funny is that at no time did you think to share your PCP and CTB files with a portion of that DWG file for others to test and examine.
But then again I like my idea better anyway. Glad you came to a conclusion you are happy with.
