How to simplify polyline
Message 1 of 10
Hello!
I have a problem with too many vertices on a 2d object. I want to lower down the number of vertices but still keep approximately the same shape.
Replies (9)
Message 2 of 10
Patchy
Message 3 of 10
Kent1Cooper
@Patchy wrote:
This will do
http://cadtips.cadalyst.com/linear-objects/polyline-diet
Thanks for the recommendation [that's my PLDIET.lsp routine].  The PLD command there does this to that shape, given a maximum distance to straighten of 50 and accepting defaults for the rest, reducing it from 368 vertices to 82:
If that turns out kinkier than you want in areas of tigher curvature, use a smaller number than 50.
Kent Cooper, AIA
Message 4 of 10
Thanks!
This really did the job and you can also decide how detailed is your object gonna be
Message 5 of 10
Kent1Cooper
@Patchy wrote:
This will do ....
... updated version >here<.
Kent Cooper, AIA
Message 6 of 10
cgh6VFSY
The link above is dead and the second link only takes me to the autodesk forum. Given how slow autocad is with polylines/splines it would be great if this could get sorted in one single software rather than fixing it elsewhere and import it back in.
Message 7 of 10
pendean
Community Legend
Community Legend
https://cadtips.cadalyst.com/linear-objects/polyline-diet
https://forums.autodesk.com/t5/autocad-forum/reduce-polyline-points/m-p/8520844#M963796
Message 8 of 10
Kent1Cooper
Cadalyst CAD Tips are currently not downloadable, and I've told them about it, and they say they're working on it.  I don't know why the other link doesn't go to a specific message, other than the vagaries of the passage of time, but in any case, here's the routine.
Kent Cooper, AIA
Message 9 of 10
pascal
Observer
Observer
does PLDiet work on  3DPolylines in AutocadLt? I'm struggling with a survey plan that is way too detailed to import into sketchup
Message 10 of 10
pascal
Observer
Observer
sorry finally found a super simple solution from these guys.. you just have to sign up but it's free and it worked instantly.
https://esurveying.net/free-lisp/reduce-polyline-vertices
