How to set Units like Metre by default.
Solved by cadffm. Go to Solution.
Solved by imadHabash. Go to Solution.
in new drawing ..you can prepare all of your own settings in one CAD dwt file . save it in one template ( dwt ) file in a specific folder and use it always by Ctrl+N .
in already used drawings ... you have to check your settings ( -DWGUNITS command ) .
Imad Habash
Please note, this is not a costless online course !?
Which setting do you mean? (what product you are talk about [please add this information to each of your threads, thx.])
AutoCAD works unitless, but some settings and feature have some kind if units
For modelspace in AutoCAD and AutoCAD LT, it is the variable INSUNITS [F1]
For new files based on templates (*.dwt), set up the template to the setting you want.
For new files NOT based on templates, MEASUREINIT controles the set up
for imperial or metric usage, insunits default values are 1 for imperial(inch?) und 4 for metric(millimeters).
Sebastian
>>"in already used drawings ... you have to check your settings ( -DWGUNITS command ) . "
Please don't start this command in plain AutoCAD files, i don't like to answer to all the question you will have in future, LOL.
Sebastian
