how to set equal distance between elements
edenbU7RGS
Message 1 of 8
edenbU7RGS
can I set equal distance between those line and block (w different attribute valve for each one) automaticity somehow? without moving each one of them manually?
the current distance is 400 and i want to change it to 425.
the dwg file is attached to the post.
Replies (7)
Message 2 of 8
imadHabash
Yes you can by ARRAY <Rectangular> command ....
For attribute levels ... you have to use Fields as described HERE.
Imad Habash
Message 3 of 8
edenbU7RGS
i know this command but i've different attribute value in each block.. the array will not help here.
Message 4 of 8
pendean
Community Legend
Community Legend
Did you use ARRAY command to space them out first by chance? @edenbU7RGS
If not you could install and use this freebie
https://apps.autodesk.com/ACD/en/Detail/Index?id=2161196326287749437&appLang=en&os=Win64
or this one
https://www.lee-mac.com/incrementalarray.html
Message 5 of 8
leeminardi
Make a block of the series of dimension.  Scale the the block by 1.0625 in Y (425/400).  I like to do the scaling via the properties panel.  Explode the block!
lee.minardi
Message 6 of 8
imadHabash
It will work by Field command as i mention it in Massage #2
Imad Habash
Message 7 of 8
AllenJessup
Convert all elements to a Block. Make sure that Scale Uniformly is not checked and Allow Exploding is checked.
Once they are a Block. Use the Properties Palette to change the Y scale to 1.0625. Then Explode the Block.
Allen Jessup
CAD Manager - Designer
Message 8 of 8
edenbU7RGS
perfect! it's works perfectly!
