AutoCAD angle not being displayed when selecting a polyline. Please see attached.
Paul_ConwayU5P5K
Message 1 of 9
Paul_ConwayU5P5K
I've tried everything in my drafting settings etc to try and find out why the angle isn't showing when i select a line and click onto one of the grip points, my civils 3d shows the angle that the line is in relation to the UCS and to the other part of the line, all my settings seem to be the same as civil 3d but the angle is still not showing up. please see the attached picture, its only showing the lengths. and not the angle between the hinge point of the 2 lines. What am I missing in the settings, I am self taught on both apps so aren't brilliant when it comes to CAD, If someone could advise me on the best settings to have in my drafting etc it would be appreciated
@Paul_ConwayU5P5K Your post title was modified to add the product name and to increase findability - CGBenner
Replies (8)
Message 2 of 9
Patchy
C3D id a lot different than plain Autocad.
Message 3 of 9
imadHabash
You may try MEASUREGEOM command (Quick option) .. Just activate the command then pass your mouse over the objects.
Command: MEASUREGEOM
Enter an option [Distance/Radius/Angle/ARea/Volume/Quick/Mode/eXit] <Distance>: Q
Imad Habash
Message 4 of 9
pendean
Community Legend
Community Legend
@Paul_ConwayU5P5K Is this a problem in ALL of your files, or just this one?
Your secret AutoCAD year version as listed in ABOUT command is...?
OS is...?
What is your DYNMODE set to? 3 here for me, all works as you describe you want it to do.
Message 5 of 9
Paul_ConwayU5P5K
Used to show angle as well as distances when selecting one of the vertices when highlighting a line..
Regards
Paul Conway
Site Engineer
M 07890 661 402<>
paul.conway@jnbentley.co.uk
[Image]
JN Bentley
Keighley Road
Skipton BD23 2QR
United Kingdom
Website<> | LinkedIn<> | Twitter<>
JN Bentley Limited is registered in England and Wales no: 1085646. Registered Office: Keighley Road, Skipton, North Yorkshire BD23 2QR.
The information contained in this e-mail is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. If you are not the intended recipient of this e-mail, the use of this information or any disclosure, copying or distribution is prohibited and may be unlawful. If you received this in error, please contact the sender and delete the material from any computer.
[signatureImage]
Message 6 of 9
AllenJessup
As @pendean mentioned. DYNMODE should be set to 3.
Allen Jessup
CAD Manager - Designer
Message 7 of 9
paullimapa
in plain autocad even with dynmode set to 3:
pline only shows segment length but not angle:
lines do show angle:
Paul Li
IT Specialist
@The Office
Message 8 of 9
Paul_ConwayU5P5K
Ah I see . So if I’d drawn 2 separate lines joined it would show the angle between the separate lines but a poly line doesn’t do that . Thought it was something and nothing . As I said I’m only self taught and my knowledge is only good enough for site engineering. Appreciate the help . Thanks
Message 9 of 9
paullimapa
you're welcome...actually with LINEs it's not showing the angle between the two but the angle of one of the LINE itself...cheers!!!
Paul Li
IT Specialist
@The Office
