AutoCAD Forum
How to rotate an inserted OLE Object ?
7 REPLIES 7
Message 1 of 8
9305 Views, 7 Replies
When i insert an OLE i want to rotate it from vertical to horizontal, but the rotate button just moved the full image around a point. HELP !
7 REPLIES 7
Message 2 of 8
pendean
OLE original orientation is maintained I believe: you will need a new attachment that is already rotated.
Message 3 of 8
in reply to: pendean
The object i am inserting though is a PDF and the only way i can insert that into CAD is via the OLE ?
Message 4 of 8
M_Hensley
You can use XREF manager to attach a PDF then scale, rotate etc.
Message 5 of 8
nestly2
You will be able to rotate if you attach the PDF as an underlay.
Message 6 of 8
in reply to: nestly2
Message 7 of 8
pendean
Message 8 of 8
alexandervshaju10
just convert the OLED object to block
Forma Design Contest
AutoCAD Beta
