When I "zoom extend" my model space, it gives me extra space, on the upper side and when I zoom out, it shows a red circle with a cross-like pattern inside it, but the overall outline of the figure is circular. And it cannot be selected/highlighted. And I can't zoom in on it either.
Solved by cadffm. Go to Solution.
Solved by ВeekeeCZ. Go to Solution.
Use GEOMARKERVISIBILITY sysvar.
Read more here
https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-47B2082F-204E-499A-99AD-96DC2BA3738F
Read more here
if you don't know what it is, hide it.
It is the Geoposition marker of the setted geo coordination system.
Command GEO
Command GEOMARKERVISIBILITY
and GEOREMOVE to remove the data
Sebastian
Command GEO
Sebastian
Thank you for your quick response!
But may I ask how I can remove the excess space above? the geomarker was already removed but the excess space is still there.
You hide the marker and using ZOOM ALL.
You need zoom extents
or remove the marker, see my post above
Sebastian
Sebastian
Corr. The marker doesn't affect zoom all.
My question: Are you using Zoom all or Zoom extents?
If Extents: There are other objects , find them
LAYER all ON and THAWED.
Or share your .dwg
Sebastian
Or share your .dwg
Sebastian
