第 1 条消息(共 4 条)
Auto CAD 2018
I am trying to replace one title block with modifications. The original title block is attached . I have remove the title block using erase command. When I am trying to xref corrected title block - the old one shows up.
In xref window the old title block is listed as attached. Detach or bind is not high lighthed. I purged all unused layers block without luck.
I need to get the project out tomorrow morning. I will keep on trying.
But in the meanwhile, I will appreciate very much if some body could help me.
已解决! 转到解答。
