AutoCAD Forum
how to reduce dwg file size?
33 REPLIES 33
Message 1 of 34
85301 Views, 33 Replies
hi everyone.
im abit lost here...
i've tried allmost everything i found on the web on how to reduce dwg file size:
purge
-purge...regapps ext.
overkill
audit
wblock
rescalling
and nothing seems to work, my file size is approx 15mb when it should be no more then 2mb
please help
thx
33 REPLIES 33
Message 21 of 34
Alfred.NESWADBA
>> can u teelll me the command ....for reducing drg.file size
(sarcasm on)
Command is: _DELETE<ENTER>_ALL<ENTER><ENTER>
(sarcasm off)
Sorry, there is not "THE ONE command" available that solves all problems with drawing sizes.
You have already shown you used "all the command" (whichever you mean by that) but for us we don't know why you think you file size is too large. A drawing-size of some 10MB or even 100MB is possible and valid.
Another size of 1MB might be too large if nothing is in the drawing.
Also a drawing size of 10MB might be reducable to 1MB if there are used other techniques then just drawing just lines.
So what is your file, what size does your file have, what size do you expect that it should have and at least what command's (listed) have you used when you say "all the command"?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 22 of 34
in reply to: Alfred.NESWADBA
I'm having 300mb
When I want to open it in my phone it tell need 30mb to open
Sent from my iPhone
Message 23 of 34
Alfred.NESWADBA
sorry, I don't understand what you are trying, sounds like you try to open the DWG file on your phone/handy. Is not clear for me what you are trying currently.
- alfred -
Alfred NESWADBA
Message 24 of 34
HI,
i did follow your instruction . I can do till "save & close in .dxf format". But when i open it again, i can not open.
Error is " Invalid symbol table record name: *Multiple on line 9178.
             Invalid or incomplete DXF input -- drawing discarded.
              Press ENTER to continue.  " i saw like that. My file is 144 Mb. It is not 3D.  I need to open about 3 or 4 files (around same size)when i draw the drawing. At that time my computer is so so slow. Please advice me.
Best regards
swe
Message 25 of 34
try this
- wblock
enter file
save
ENTER
CLOSE AUTOCAD & do not save that file enter no
open autoCAD file
and see the file size is reduced
Message 26 of 34
- wblock
enter file
save
ENTER
open autoCAD file
Message 27 of 34
save as dxf file and close the file, open the dxf file and save as in dwg. 2 -3 time
Message 28 of 34
ams1511
Hi every one, I am sorry that I re open an old discussion.
But I have the same problem!
I try this steps: Detach any unneeded xrefs - Remove any unnecessary images -  purge command - overkill command - LayDel
But it didn't work!!
Can any one help
My file is Attatched
Message 29 of 34
in reply to: ams1511
1. SAVE AS FILE IN DXF FORMAT
2. CLOSE DXF FILE
3. OPEN DXF FILE AND SAVE AS .DWG
DO SAME PROCEDURE 2 AND 3 TIME
*Irfan Behlim*
Dubai UAE
Mob.: +971-556335518
mail to:irfanm05@gmail.com
*P* *Please consider your environmental responsibility before printing this
e-mail.*
Message 30 of 34
ams1511
Thanks irfanm05
I tried that but dxf file became 160 MB then I Cant open it ( Autocad dosen't Respond)
Message 31 of 34
SEND ME YOUR FILE
https://www.wetransfer.com/
*Irfan Behlim*
Dubai UAE
e-mail.*
Message 32 of 34
ams1511
My friends thank you K It works finally, I wait for autocad about 1 hour and thet it fixed!!
Message 33 of 34
hi friend;
 i used the dgnhotfix to reduce your file size
 ive managed  to reduce it to 95 kb
enjoy
Message 34 of 34
ParishSouthBdx
I was certain it was BREP.
grrr... ha ha
Tags (1)
AutoCAD Inside the Factory
