hi everyone.
im abit lost here...
i've tried allmost everything i found on the web on how to reduce dwg file size:
purge
-purge...regapps ext.
overkill
audit
wblock
rescalling
and nothing seems to work, my file size is approx 15mb when it should be no more then 2mb
please help
thx
Solved by braudpat. Go to Solution.
>> can u teelll me the command ....for reducing drg.file size
(sarcasm on)
Command is: _DELETE<ENTER>_ALL<ENTER><ENTER>
(sarcasm off)
Sorry, there is not "THE ONE command" available that solves all problems with drawing sizes.
You have already shown you used "all the command" (whichever you mean by that) but for us we don't know why you think you file size is too large. A drawing-size of some 10MB or even 100MB is possible and valid.
Another size of 1MB might be too large if nothing is in the drawing.
Also a drawing size of 10MB might be reducable to 1MB if there are used other techniques then just drawing just lines.
So what is your file, what size does your file have, what size do you expect that it should have and at least what command's (listed) have you used when you say "all the command"?
- alfred -
>> When I want to open it in my phone
sorry, I don't understand what you are trying, sounds like you try to open the DWG file on your phone/handy. Is not clear for me what you are trying currently.
- alfred -
HI,
i did follow your instruction . I can do till "save & close in .dxf format". But when i open it again, i can not open.
Error is " Invalid symbol table record name: *Multiple on line 9178.
Invalid or incomplete DXF input -- drawing discarded.
Press ENTER to continue. " i saw like that. My file is 144 Mb. It is not 3D. I need to open about 3 or 4 files (around same size)when i draw the drawing. At that time my computer is so so slow. Please advice me.
Best regards
swe
try this
- wblock
Hi every one, I am sorry that I re open an old discussion.
But I have the same problem!
I try this steps: Detach any unneeded xrefs - Remove any unnecessary images - purge command - overkill command - LayDel
But it didn't work!!
Can any one help
My file is Attatched
