How to print many overlapping layers in different sheets
IONRINGACI01
IONRINGACI01
Community Visitor
Community Visitor
HI. I have the task of printing more than 150 technical drawings, but each drawing is superimposed on the other with a different layer. (1 layer = 1 drawing). I ask if it is possible to automate this work and not have to change layers and print one drawing at a time. Thank you
paullimapa
Wow, I don't know what field of practice would actually produce or compose a drawing where each Layer is a separate drawing and needs to be the only Layer left on in order to get a proper hardcopy.
You'll have to rely on a lisp function to cycle through each Layer, print that Layer to a PDF with perhaps the filename with the Layer Name appended to the Drawing name so that it'll be unique.
But still you'll need the Plotting parameters and assuming those are the same for each Layer then it'll work.
Paul Li
IT Specialist
@The Office
Valentin_CAD
@IONRINGACI01 ,
Search in the Autodesk App Store for something like SonOfABatch or JTB Batch Plot Trial.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
RSomppi
Whoever made the drawing should have set-up a layout tab for each sheet. Are they present in the file?
