AutoCAD Forum
How to open parasolid x_t file from Autocad
9 REPLIES 9
Message 1 of 10
37027 Views, 9 Replies
I am trying to open parasolid x_t extension file from autocad 2016 (either electrical or mechanical), but no luck. Do have any guidance to open or convert this x_t to dwg file.
Thank you
Ty
9 REPLIES 9
Message 2 of 10
pendean
Parasolid (*.x_t) are Parasolid text files, are they not?
You need Autodesk INVENTOR to import them flawlessly I believe if nothing comes in with AutoCAD's IMPORT command.
Message 3 of 10
in reply to: pendean
Hi Dean,
I tried to use Autodesk Inventor too, but I could not open it either.
Tks
Ty
Message 4 of 10
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I think you should be able to open them in Fusion 360.  Here is an article that describes the process. You are welcome to attach a file and i can give it a try as well.
John Vellek
Message 5 of 10
BeKirra
I use the same version of AutoCAD and I had x_t files without any issues - AutoCAD may take a longer time to get it open, it depends on the file size.
Is your file damaged?
And other thought is that the version of x_t - I could be wrong.
Is your x_t file the latest version? Can AutoCAD mech 2016 open the latest version of x_t?
From HELP:
"Import" command.
In Files of type, select the file format to import. In File Name, select the file name to import. The file is imported into the drawing.
The following formats are available for import for AutoCAD.
JT (*.ij)
Parasolid (*.x_b)
Parasolid (*.x_t)
Pro/ENGINEER (*.prt*; *.asm*)
Pro/ENGINEER Granite (*.g)
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 6 of 10
pendean
Your file may be damaged: post it here for others to try and confirm if it is.
Message 7 of 10
in reply to: john.vellek
John,
I included the *x_t file  if you can open it and covert it to dwg file.
Thank you.
Message 8 of 10
john.vellek
Hi Thuan,
I was able to import this file into AutoCAD 2018 very quickly without any errors being reported. I have attached my drawing file for you to examine.
John Vellek
Message 9 of 10
John,
Thank you
Ty
Message 10 of 10
I am also attempting to open a Parasolid file in AutoCAD and am getting an error that my file is an unsupported version and that I must have V7 or V8 files. How do I force Solidworks to generate V7 or V8 files?
Forma Design Contest
AutoCAD Beta
