How to open Autocad from excel and run a script, any tips would be helpful.
Hello, New to these forums as in it's my first post, been using the forums quite a bit however in the last week weeks to finely tweak my VBA macros etc... I'm trying to make an excel macro that will --> open auto cad --> run a script.... I have a few columns linked to another excel file and thats where the output goes too from running this script, just trying to streamline the process a bit more, thanks.
Alfred.NESWADBA
this is a short code-snippet to connect to AutoCAD or start AutoCAD.
Const AcAppClID As String = "AutoCAD.Application"
Public Sub startAcad()
   Dim tAcObj As AcadApplication
   On Error Resume Next
   'try if AutoCAD already is started
   Set tAcObj = GetObject(, AcAppClID)
   If tAcObj Is Nothing Then
      'AutoCAD is not running or not reacting, so we create a new process
      Set tAcObj = CreateObject(AcAppClID)
      'if that failed too something not correct
   Else
      tAcObj.Visible = True
End Sub
Make sure you have added the references to AutoCAD libs as this helps you during development.
You can later change all to "Object" and late-bound, but I would not run the development with that option.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank you for your reply, i'm still having trouble however when it comes to using something alongthe lines of this
tAcObj.SendCommand EXTRACTLINE
If i use something very similar in autocad VBA it will work but I cannot get it working in this instance. I tried a few other ways of typing it but all to no avail. Any suggestions?
Alfred.NESWADBA
Sorry no, that would not work in AutoCAD VBA as the AcadApplication object does not have a method "SendCommand".
Therefor you need a AcadDocument type, e.g.
   Dim tAcDoc As AcadDocument
   Set tAcDoc = tAcObj.ActiveDocument
   tAcDoc.SendCommand ("_LINE" & vbCr)
- alfred -
Alfred NESWADBA
Awesome Alfred, Your code is 100% working, my problem now stemming from the command/script im trying to run is a custom script to extract line numbers and when im sending that specific command, it does nothing inside of ACAD.
