Export to a STP file in AutoCAD 2016... how to?
Export to a STP file in AutoCAD 2016... how to?  STEPOUT does not work.
thanks,
bobb
j.palmeL29YX
In Vanilla AutoCAD AFAIK not possible.
cadder
Jürgen Palme
thank you. so what additional software is required?
Alfred.NESWADBA
if you have the "Only One AutoCAD" subscription you might download and install the Mechanical toolset, load your drawing with Mechanical and there you have the option to export a STEP file (take care about the objects you try to export, should be standard AutoCAD geometry and not any type of vertical AutoCAD objects like Civil 3D surface or Architecture walls or something like that).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Johanna_Esteban
Hi @bob.b.williams
You can take it to Autocad as dwg file through Inventor.
See Screencast:
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
