How to move dimension text to another side
Dear all,
            How I can move the dimension text to another side of the dimension line as in attached image.
find the attached file.
Alfred.NESWADBA
Select the dimension so you get the grips displayed.
Now move your cursor to the text-grip point, but don't click it ... after a second (about) you get a context menu with the option "Move Text Only" ==> click that option and your text is ready to be moved.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
by DDIM command and by modifying text placement you can get many options. BUT as you ask you can get it by changing the Vertical text placement to Outside option and as shown in the below image example .
Imad Habash
