>> how can I confirm that dome is solid?
Either run command _LIST and select your object, or open the property window and look to the top line while your object is selected.
>> Because i cant Union both parts
Look to the command-line when you start the command _UNION, it tells you:
At least 2 solids, surfaces, or coplanar regions must be selected.
So as the dome is a 3D-Solid the other object is it not, and I guess the second object you selected was the array, am I correct?
An array is not a 3D-Solid (even if it consists of 3D-Solid objects).
What you can do is to start command _EXPLODE, select the array ==> so the parts of the array are selectable now ... then you can run command _UNION with the other elements + the dome.
[EDIT] if you want to run _UNION with the parts of the array, you'll need first to make 3D-Solids from that parts, that are only surfaces.
Sorry, have not seen that before [/EDIT]
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
