>> How I can move the dimension text to another side of the dimension line
Select the dimension so you get the grips displayed.
Now move your cursor to the text-grip point, but don't click it ... after a second (about) you get a context menu with the option "Move Text Only" ==> click that option and your text is ready to be moved.
- alfred -
by DDIM command and by modifying text placement you can get many options. BUT as you ask you can get it by changing the Vertical text placement to Outside option and as shown in the below image example .
Imad Habash
