How to move a line into an angle
Message 1 of 9
Hello everyone
i hope you are all fine. I have a strange problem. I want to move a specific dimensions horizontal line into an angle of 2 other lines so it can fit and create an triangle(i am attaching image).
I dont know how to do it.
Can anyone help me?
thanks in advance
Replies (8)
Message 2 of 9
j.palmeL29YX
I'm not sure if I understand your question right.
Maybe the Screencast https://autode.sk/2BY55oX helps you. (BTW: If your line is horizontal, you can type a Reference Angle = 0, in the video I picked 2 points).
cadder
Jürgen Palme
Message 3 of 9
ennujozlagam
Hello, I don't understand either your question, so you can use this command SNAPANG and XLINE to get the angle. Thanks Smiley Wink
Message 4 of 9
thanks for your reply
I dont want to rotate the base line because it is horizontal (its dimencion is fixed = 1500). I want to move this line so it can intersect in the angle and create a triangle.
Message 5 of 9
thanks for replying
I am sorry but I am a newbie!
I am attaching what I want to do
I want to move the base line up so it can touch the 2 other lines so they can create an triangle. I must not rotate the base line(the exercise demands this line to be horizontal and its length to be 1500)
thanks for your time
Message 6 of 9
j.palmeL29YX
@Anonymous  schrieb: I want to move this line so it can intersect in the angle and create a triangle.
OK. I hope now I understand you:
https://autode.sk/2BZt2Mm
cadder
Jürgen Palme
Message 7 of 9
Oh YES thats is.
Thanks a lot for your help...
Words can not describe how happy I am hehe.
Thank you all
Message 8 of 9
vladimir_michl
Or without any auxiliar geometry - using constraints:
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 9 of 9
Kent1Cooper
You can eliminate a step in the procedure in Message 6.  [I did it here by Copying the right-side angled Line rather than the left as in the screencast, but the principle is the same.]  You don't need to Move the one Line twice.  Step 0 below is initial conditions, with the endpoints of the red Line being A and B.  Just [step 1] copy one of the Lines forming the bend [here the yellow one] using B to A for the Copy displacement [or A to B if you Copy the cyan one], and [step 2] Move the red Line from A to the intersection of that [yellow] copy with the other [cyan] bend Line.
Then erase the temporary yellow Line.
Kent Cooper, AIA
