AutoCAD Forum
How to make slope? Been stuck there for hours.
2 REPLIES 2
UkuuXDMT322
313 Views, 2 Replies
Hey, I have been trying to add slope there, where lines are, so the rim inner part should be lower and outer side should be higher, but i cannot find a way to make it, been on google but didnt find anything to fix it.
Thank you,
Uku.
2 REPLIES 2
parkr4st
in reply to: UkuuXDMT322
post the dwg. it would be easier to do.
draw a triangle on a radial midway between a pair of those lines, revolve it and subtract out the holes between spokes.
or make triangles of a pair of those lines, loft a solid between the triangles, radial array 6 times, and add to the spokes.
dave
UkuuXDMT322
in reply to: parkr4st
Thanks, i will give it a try 🙂
AutoCAD Inside the Factory
