How to import a PAGE SETUP into multiple DWGs
Basam.Yousif
Advisor Advisor
Message 1 of 15
Basam.Yousif
Use Autodesk's DWG TrueView program (which -I believe- is a free download)
https://www.autodesk.com/products/dwg-trueview/overview
BasamYousif_0-1707876288030.pngBasamYousif_0-1707876288030.pngBasamYousif_1-1707876374070.pngBasamYousif_1-1707876374070.png
Replies (14)
Message 2 of 15
ennujozlagam
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-AD77C304-90AC-43E2-8380-434FFEF7C4D7
Message 3 of 15
cadffm
if you like to share such tips without reason, look at this format too.
https://forums.autodesk.com/t5/autodesk-community-tips-autocad/tkb-p/autocad-tips-tricks
Just one point: Avoid to show changes of standard predefined setups, create your own.
And: If AutoCAD is available, it is onboard, command: DWGCONVERT
Sebastian
Message 4 of 15
Simon_Weel
The screenshots are about 'DWG Convert' (which is called eTransmit in AutoCAD) - not Pagesetup? So is your question about Pagesetup or DWG Convert?
Message 5 of 15
cadffm
No, the command equal to is DWGCONV, etransmit doesn't have the same possibilities,
and another point: DWG Trueview is for free, for AutoCAD internal commands you need AutoCAD (and a license)
It wasn,t a question, it is a tip for people who don't know this option.
Sebastian
Message 6 of 15
Michiel.Valcke
Not sure if it's possible in trueview, but with batch plot (publish) you can set the pagesetup from your first chosen sheet and then apply it to all the other sheets in the list even if they do not have that pagesetup in their document.
Message 7 of 15
cadffm
In publish command you can do this for the plot only, it doesn't change your layout pagesetups in your DWG.
in DWGconvert (in TrueView) you can change pagesetups in your DWGs files for (all) layouts.
Sebastian
Message 8 of 15
Basam.Yousif
This is a How-to post, not a request for help. Thank you for all your feedback.
Message 9 of 15
dany_rochefort
@Basam.Yousif  I've wrote a lisp command that does this in 1 second.
Message 10 of 15
dany_rochefort
FYI: Writing a How-to-Post and accepting your own post as the Answer is a bad look.
Message 11 of 15
WeTanks
@dany_rochefort
Could you please share your LISP file?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 12 of 15
dunnkurt_a_ipi
Community Visitor
Community Visitor
HOW
Message 13 of 15
Michiel.Valcke
@dunnkurt_a_ipi
start the publish command
Add all the layouts that you wish to print (can be from different dwg's)
Move the layout with the desired print setup (it has to be a named setup) to the top of the list
select (highlight) all the layouts in the list (use shift+select)
In the page setup dropdown menu of the top item, select your named setup
All other layouts will apply the same setup during the publish (as was mentioned by cadffm, this will NOT add the setup to the file/layout)
To create a named page setup
type the command PAGESETUP in a layout,
Choose the option 'New'
Give it a name and determine all settings (like which plotter to use/papersize/ etc...)
When done you will see the named setup in the setup list in the Page Setup Manager
To link the named setup with the active layout, use the 'Set Current' button.
Message 14 of 15
cadffm
You can use pagesetups from all files, not from one selected only.
How: Select all your layouts in your list, RIGHTclick..
Sebastian
Message 15 of 15
cadffm
But this is for publishing only, it will not import any pagesetup to any DWG file.
Sebastian
