How to import a PAGE SETUP into multiple DWGs
Basam.Yousif
Basam.Yousif
Use Autodesk's DWG TrueView program (which -I believe- is a free download)
https://www.autodesk.com/products/dwg-trueview/overview
Responder
Soluciones aceptadas (1)
713 Vistas
10 Respuestas
Respuestas (10)
ennujozlagam
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-AD77C304-90AC-43E2-8380-434FFEF7C4D7
0 Me gusta
cadffm
if you like to share such tips without reason, look at this format too.
https://forums.autodesk.com/t5/autodesk-community-tips-autocad/tkb-p/autocad-tips-tricks
Just one point: Avoid to show changes of standard predefined setups, create your own.
And: If AutoCAD is available, it is onboard, command: DWGCONVERT
Sebastian
0 Me gusta
Simon_Weel
The screenshots are about 'DWG Convert' (which is called eTransmit in AutoCAD) - not Pagesetup? So is your question about Pagesetup or DWG Convert?
0 Me gusta
cadffm
No, the command equal to is DWGCONV, etransmit doesn't have the same possibilities,
and another point: DWG Trueview is for free, for AutoCAD internal commands you need AutoCAD (and a license)
It wasn,t a question, it is a tip for people who don't know this option.
Sebastian
0 Me gusta
Michiel.Valcke
Not sure if it's possible in trueview, but with batch plot (publish) you can set the pagesetup from your first chosen sheet and then apply it to all the other sheets in the list even if they do not have that pagesetup in their document.
0 Me gusta
cadffm
In publish command you can do this for the plot only, it doesn't change your layout pagesetups in your DWG.
in DWGconvert (in TrueView) you can change pagesetups in your DWGs files for (all) layouts.
Sebastian
0 Me gusta
Basam.Yousif
Solución aceptada
This is a How-to post, not a request for help. Thank you for all your feedback.
0 Me gusta
dany_rochefort
@Basam.Yousif  I've wrote a lisp command that does this in 1 second.
0 Me gusta
dany_rochefort
FYI: Writing a How-to-Post and accepting your own post as the Answer is a bad look.
0 Me gusta
WeTanks
@dany_rochefort
Could you please share your LISP file?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
0 Me gusta
