How to get rid of "Select Shape File" dialog box
mikegera
mikegera
AutoCAD 2000 question:
The "Select Shape File" dialog box keeps popping up when we open drawings.
How to we prevent this permanently?
Thanks!
Alfred.NESWADBA
you get that dialog every time a drawing searches for an SHX file but does not find it.
If the SHX file is missing AutoCAD can't display the linetypes correct or shows text objects with another/wrong font.
Either you have that missed SHX-file, then place it in one of the AutoCAD support folders (or edit the options in AutoCAD and add a support folder to the folder the SHX file is stored).
If you don't have the SHX file first try to get it (ask the one who created that drawing) ... or change the linetypes which use this SHX to another linetype.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
Sometimes, not always, a WBLOCK of your entire modelspace content to a new file can get rid of it if it is not used in the objects you select.
JTBWorld
Not a permanent solution but a workaround is to have an app closing the dialog box automatically. See our freeware app here.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
cfandrich
If you want to permanently ignore it and not know if there are missing SHX files, then the steps are:
To bring back the Missing SHX Files dialog and turn off the prompt in the future, do the following:
  1. Type OPTIONS and press enter.
  2. Open the 'System' tab and click 'Hidden Messages Settings'.
  3. Reactivate the message for .shx files.
  4. Click 'OK' and 'Apply'.
  5. Close and re-open Civil 3D and open the DWG giving the error.
  6. When the 'Missing SHX' files message appears, select "Ignore the missing SHX files and continue" and check Always perform my current choice.
Found here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cannot-turn-off-th...
cadffm
Impossible in AutoCAD2000 😉
Sebastian
cfandrich
Oh geeze Sebastian! I totally missed that part!! Thank you 🙂
