AutoCAD Forum
How to get outside contour from a cloased polyline?
3 REPLIES 3
431 Views, 3 Replies
I need some help, i have a closed polyline (with self-intersection inside if it matters), so i need to get only contour from the outside(i meen the shell). Does such a command or function exist? Thanks and  Excuse my grammer.
3 REPLIES 3
pendean
Show us what that looks like please, thanks.
Alfred.NESWADBA
draw a rectangle that is bigger then  all your existing objects (which are then all inside that rectangle), then use command _BOUNDARY with picking a point inside the rectangle, but outside your original objects (make sure island detection is on)
You can then delete the rectangle with the polyline created from the _BOUNDARY command, and you should have gotten a second polyline that goes around your existing objects.
Create a new layer before starting the command, this will give you a better chance to select the polyline(s).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thank you so much! 😃 It works! :confetti_ball::party_popper::party_popper:
AutoCAD Inside the Factory
