I need some help, i have a closed polyline (with self-intersection inside if it matters), so i need to get only contour from the outside(i meen the shell). Does such a command or function exist? Thanks and Excuse my grammer.
Solved by Alfred.NESWADBA. Go to Solution.
draw a rectangle that is bigger then all your existing objects (which are then all inside that rectangle), then use command _BOUNDARY with picking a point inside the rectangle, but outside your original objects (make sure island detection is on)
You can then delete the rectangle with the polyline created from the _BOUNDARY command, and you should have gotten a second polyline that goes around your existing objects.
Create a new layer before starting the command, this will give you a better chance to select the polyline(s).
- alfred -
