How to get coping to loft on radius that are on different planes
joeQW4TM
Message 1 of 8
joeQW4TM
I am trying to get a wall cap to loft on both a radius on the plan view and elevation.
I have attempted to use guides but it has failed. any help getting this done would be greatly appreciated.
Replies (7)
Message 2 of 8
Washingtonn
Create a horizontal lofted curved solid and a vertical lofted curved solid. Use the Intersect command on the solids to get the resulting solid incorporating both curves.
Message 3 of 8
imadHabash
@joeQW4TM
Could you please explain to us in more detail what you want to do? It would be fine if you could draw by hand sketch what you intend to do so that we understand your request precisely.
Is that your need ... 👇
Imad Habash
Message 4 of 8
joeQW4TM
@imadHabash
here is a snippet of what i am trying to accomplish in elevation.
the foot print of the wall is a half circle.
Message 5 of 8
Kent1Cooper
I suspect what you really need as a path for a Sweep or Extrude or Loft operation, on the part that curves in both directions, is a HELIX with only part of one turn.
That was done with a Rectangle EXTRUDEd along a Helical quarter-turn path.
Kent Cooper, AIA
Message 6 of 8
leeminardi
Something like this?
I created a spline with 3 fit points from the red arc then dragged the fit points vertically with ortho lock to match the desired elevation. Loft with the spline as guide finished the shape.
lee.minardi
Message 7 of 8
charleswilson0090
If the cap is changing on a radius in both plan and elevation, SWEEP along a clean 3D path is often more reliable than LOFT, especially if your section stays constant. If you want to keep using LOFT, make sure every profile is closed, planar, and aligned in the same direction, and that each guide curve intersects every section exactly at a common point or the loft will usually fail.
Message 8 of 8
Washingtonn
Result from intersecting two solids. The horizontal shows the solid tapering slightly (side to side) to the center point of the plan view radius.
(view in My Videos)
