Earthworks Batter Linetype
chrispooley0
Message 1 of 9
chrispooley0
Hi All,
I'm a newbie to Autocad from Revit & Archicad.
I am trying to create a linetype that represents cut and fill batters, for civil engineering works, this is commonly done with a 'Y' shape pointing downhill in the area I work in.
I have managed to create the linetype and the shape file, but it is not behaving as I would like it to. There are 2 main issues:-
  1. there is a gap from the start and end of the line, and
I have also uploaded my .dwg file with the linetype loaded into it.
Any ideas how I can fix these?
Thank you,
Replies (8)
Message 2 of 9
Kent1Cooper
Show us the linetype definition.  Exactly how it's defined could affect the gap issue.  And post the Shape file.  But in the case of the three-arc-segment Polyline, change its Linetype Generatioin in Properties to Enabled.
No matter by what method you draw it, an Arc's ultimate "drawn direction" is always counterclockwise.  So if you want an Arc to be "drawn" in the clockwise direction for the sake of the "aim" of the Shape inclusions, it must be done as a Polyline arc segment.
Kent Cooper, AIA
Message 3 of 9
chrispooley0
Hi Kent,
How do I access the definition? According to google I open the linetype manager, however this doesn't tell me anything about a definition.
For drawing the arc.  Changing the generation to enabled worked perfectly.
Message 4 of 9
Kent1Cooper
@chrispooley0 wrote:
....How do I access the definition? ....
Somewhere there is a file with a .lin filetype ending that contains the definition.  The basic ones that come with AutoCAD are acad.lin and acadiso.lin.  Yours may have been added into one of those, or it might be in a different file; it could be in a file by itself [maybe even with the same name], or in one containing multiple definitions.  If you used the MKLTYPE Express Tool to create it, hopefully you remember where you asked for it to go.  If you load it into drawings other than the one in which you used MKLTYPE to make it, you must know where you're getting it from.
Open that file in a plain-text editor such as Notepad.  Its definition will look like this:
*BATTER,Optional description, optional visual approximation like maybe YYYYYY
A,the Definition.....
Kent Cooper, AIA
Message 5 of 9
chrispooley0
Hi Kent, thank you for helping me with this.
Thats it there
*BATTER,Earthworks Batter
A,0,[Y,C:\Drafting on PC\AutoCAD\AutoCAD Templates\AutoCAD Lines\Y,s=.75],.55
Message 6 of 9
chrispooley0
Sorry, I just noticed this
Message 7 of 9
Kent1Cooper
For the gap issue, try starting the definition with a very small but non-zero pen-down bit:
A,.001,[Y,C:\Drafting...
The ends still won't have the Shapes right up to the end except when the length of the object is right in relation to a multiple of the definition cycle length.  There should be continuous-line ends filling out the object length, but not gaps.
[Untested -- I didn't revise the definition for a different filepath, load everything up, etc.  If my suggestion doesn't work, I can do that for further trial.]
Kent Cooper, AIA
Message 8 of 9
charleswilson0090
You’re probably very close. This usually comes down to the .lin pattern setup and the shape insertion point in the .shx file.
Message 9 of 9
chrispooley0
Wonderful,
Thank you Kent, worked perfectly.
