Show only
Search instead for
How to generate excel sheet while measuring on the cad drawing.
i am doing quantity take-off using autocad 2017 version,. is there any way I can generate tables while measuring on the drawing?Something that tables are on the drawing itself.
The DATAEXTRACTION command can generate tables based on data in the drawing. I can be a little bulky sometimes but its quite useful. Might take a few tries before you get the table you want.
If you are just looking to sum lengths or something along those lines you can insert a nest field into table you insterted into your drawing. (this might be a little tedious as you will have to build the formula as you go)
