I like to drawing in AutoCAD 2010. But some days ago I opened my .dwg file and it viewed me: Non Autodesk DWG. I don’t know where to find repair tool for dwg file.
@Anonymous,
john.vellek has edited your subject line for clarity: when .dwg file isn’t opened
Solved by john.vellek. Go to Solution.
That isnt an Error.
Look at SysVar DWGCHECK (F1) perhaps you changed the Value (changed the Profile with other DWGCHECK-Value?)
Sebastian
Did the file open or not?
.DWG file format is one of the most popular among graphic files. Moreover, in situation nothing ordinary cannot help you, and then look at https://www.repairtoolbox.com/autocadrepair.html – it especially created for complicated cases with .dwg files.
HI
You can use this command "_DRAWINGRECOVERY" to brows and repair file.
Good Luck
Please select the Accept as Solution button if my post solves your issue or answers your question
Hi @Anonymous,
Try using EXPORTTOAUTOCAD to get this in a totally "native" AutoCAD format.
You are welcome to attach the file to a post for me to examine.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
