How to extend two lines to their common point of intersection?
Message 1 of 8
Just a quick opne. See the attached files: two lines, and i want to extend both to their common point of intersection rather than extend one too far, extend the other one to meet it, then trimming the first line back.
The above workaround is sufficient but I keep finding I have to do this sort of thing so it's worth asking if there's a quicker way. Cheers
Replies (7)
Message 2 of 8
nestly2
Change EDGEMODE = 1   or FILLET with a 0 radius
Message 3 of 8
Ah much better, extend and trim work more intuitively with edgemode set to 1 IMO too, thanks!
Message 4 of 8
jean_luc_mallet
Thank you
Message 5 of 8
samuel_coats
Community Visitor
Community Visitor
Fillet with 0 radius... what an amazing trick. Thank you!
Message 6 of 8
cadffm
fillet or chamfer..
Hold [Shift] while fillet-or-chamfer and it is acting like filletrad-or-chamfer[a/b] set to 0, no matter what value are current.
Sebastian
Message 7 of 8
Kent1Cooper
And yet another way if they're LINE objects specifically [not, for example, Polylines]:
CHANGE
{select them}
APParent-intersection object snap and pick on each again
If they're not orthogonal, it needs ORTHO mode to be off.
Kent Cooper, AIA
Message 8 of 8
hubert_despres
Community Visitor
Community Visitor
Hi, Thanks a lot, I have not used auto cad in about 10 years and I was really scratching my head for this command. 👍
