Paste command not working
zachUDEDM
Message 1 of 20
zachUDEDM
 I'm trying to copy items from one drawing into another but for some reason when I use the paste command, nothing is showing up on the drawing.  It looks like the copy command is working and I'm not getting an error message.
Any idea what's happening or if there's a workaround I can try?
Replies (19)
Message 2 of 20
pendean
Community Legend
Community Legend
Are you sure the content you are pasting are just not way offscreen outside your immediate view?
and/or do you need to thaw/turn on all of your layers afterwards and REGENALL before looking for them off screen?
BTW there is always an error message if it fails.
Message 3 of 20
zachUDEDM
To test it, I tried to copy and paste it right next to the original object in the same drawing.  So yes the layers are fine since I can see the object I'm copying and I'm using a base point on the object so it would paste in on my mouse.
Same result.
If there is always an error message, then is there somewhere I can find that it would be logged?
Message 4 of 20
pendean
Community Legend
Community Legend
Does this problem occur in any other drawings, or just this one DWG file?
Message 5 of 20
zachUDEDM
All drawings.  I've also tried using the right click command just in case it was an issue with the keyboard shortcuts but that didn't work either.  I did manage to paste in image files and text files from other programs just fine.  But when I try copying anything from autocad to autocad, nothing happens.
Message 6 of 20
pendean
Community Legend
Community Legend
AutoCAD to AutoCAD? as in two separate program sessions? That never works, never has, never will AFAIK.
If you mean between two open DWG file windows in the same AutoCAD session, that works fine for almost everyone except you at the moment for some reason.
Which is it?
Post screenshots of your ABOUT command pop-up, as well as your GRAPHICSCONFIG command pop-up, and also list your OS for us please.
TIA
Message 7 of 20
Kent1Cooper
Something appears to be wrong with your PASTECLIP command.  When I use it, I get an insertion-point prompt that is not in your image:
Might you need a repair/reinstallation?
Kent Cooper, AIA
Message 8 of 20
zoe58E39
Community Visitor
Community Visitor
Did this work? I'm having the same problem.  It was working fine up until a minute ago, now I can't paste anything.  (Copy command works fine, but ctrl+C ctrl+V just shows nothing, even though it says it's pasting in the command bar.
Message 9 of 20
tcarrBDA
I'm having the same problem sporadically.  I haven't been able to find a pattern in the failures.  I am using 2023.
Message 10 of 20
pendean
Community Legend
Community Legend
Sadly, there is no universal fix for "sporadically": does restarting your AutoCAD help resolve the issue by chance?
Is there an error at the commandline you might have missed? Make sure it is 3-5 line tall next time it happens and see what AutoCAD is trying to share with you.
Does your OS Login TEMP folder need emptying?
Have you installed the 2023.1.5 Update yet? It is required, ABOUT command inside your AutoCAD2023 will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
Message 11 of 20
tcarrBDA
It may have been the temp folder.  Upon further review I discovered I had no available disk space and took the afternoon for some targeted cleanups. The problem went away with the other junk.
Message 12 of 20
claire_floodNVZD9
Community Visitor
Community Visitor
i am also having this issue. there is no 'Specify insertion point' like there usually is. i have tried restarting autocad and its not working between any open dwg files. no errors in the command line either.
Message 13 of 20
pendean
Community Legend
Community Legend
@claire_floodNVZD9 wrote:
i am also having this issue. there is no 'Specify insertion point' like there usually is....
Ensure your commandline is on and for now about 5-10 lines tall, then do it all over again: start in the source file to CTRL+C (aka "copyclip' command) then look at the commandline for an error message. If you see none then in the destination file use CTRL+V (aka "pasteclip" command) and see if there is an error message.
Now you'll know what is going on. Share a screenshot of that error here if you need further assistance.
Message 14 of 20
sonakshi_goyalX6YS5
Community Visitor
Community Visitor
I am facing the issue
Message 15 of 20
cadffm
still after reboot?
Sebastian
Message 16 of 20
RocksterB
I just had this issue. I discovered someone had frozen the current layer and AutoCAD wouldn't paste. My problem is solved.
Message 17 of 20
tcarrBDA
Thank you.
Like taking a deathly ill child to the emergency room, my issued cleared up as soon as I asked for help. Don't know why it started or why is cleared up.. I suspect a similar issue to yours. Thanks again!
Message 18 of 20
ll9780l
Community Visitor
Community Visitor
ctrl+shift V worked for me. This pastes it as a block
Message 19 of 20
cadffm
and CTRL+V not?
Sebastian
Message 20 of 20
Jerome_Byaruhanga
Community Visitor
Community Visitor
I had the same issue and found out that somehow the layer I was trying to paste to was FROZEN. Once I unfroze it, all of my attempts to paste the item became visible - filled the whole sheet 😄
