AutoCAD Forum
how to edit group
4 REPLIES 4
21148 Views, 4 Replies
how to edit group
I have a group looks like a table, however, I can't edit the table. so How to edit a group?
4 REPLIES 4
gpcattaneo
PICKSTYLE = 0
john.vellek
HI @Anonymous,
Can you share the file so I can get a better idea of your problem?
John Vellek
john.vellek
HI @Anonymous,
Did you get this issue with the group resolved? If you can't select the group check the PICKSTYLE variable and set it to 1 or 3. If you can select but not edit it is it possible that it exists on a locked layer? If you attach your file I am happy to take a look at this issue for you.
John Vellek
gotphish001
Holding cntrl lets you pick individual objects in a group also if you don't want to permanently change the pickstyle variable.
Also for some reason sometimes a group can't be exploded. I found there is actually an UNGROUP command that will dissolves the group.
Nick DiPietro
Cad Manager/Monkey
Technology Administrators
