AutoCAD Forum
batch plot not keeping frozen layers frozen
3 REPLIES 3
1066 Views, 3 Replies
title kind of says it all. when i batch plot and publish to pdf the frozen layers become visible, however if i just plot a single layout tab the frozen layers remain frozen. i know there have been similar posts but none had a good answer so i figured id try again.
3 REPLIES 3
john.vellek
HI @Anonymous,
Is this happening on all of your drawings or just one project?  Can you attach a sample to a post for me so I can take a look? Which version of AutoCAD are you using?  Are you publishing in the background? Try toggling that off and let me know if the layers remain as they should.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my suggestion helped your Publish issue displaying frozen layers.  Please add a post to let me know if the issue persists.
John Vellek
in reply to: john.vellek
my apologies i forgot to check back in on this. the issue was my visretain was set to 0 not 1. its always something simple. i also misnomered on the batch plot i was actually publishing rather than plotting.
Technology Administrators
