Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
How to create .EPS file from Autocad 2017
How to create .(eps) file from AutoCad 2017.
Replies (10)
vladimir_michl
You can use the PSOUT command to create .EPS from your drawing. See:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=1784
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
When I apply PSOUT command it gives the following dialog box as attached.
it just saves all the drawing to .eps format, mean not giving any window option.
vladimir_michl
The Option dialog is under Tools>Options as the tip suggests.
when i create .eps file from _PSOUT command and import to adobe photoshop for rendering it is very light results as in attached images.
vladimir_michl
It is a matter of paper size, resolution and the default lineweights - we have extended the tip on how to handle lineweights.
john.vellek
Hi @Anonymous,
If you also use Illustrator, I have found the best workflow for me is to save the drawing to a version that your version of Illustrator can open and then open it there. Once open in Illustrator, getting it to work properly in Photoshop is a breeze.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @vladimir_michl's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
paullimapa
same way as previous versions of AutoCAD using the print command with EPS printer:
https://forums.autodesk.com/autodesk/attachments/autodesk/529/46771
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
how is it possible in 2017?
add a plotter wizard.
paullimapa
Again same as previous versions of AutoCAD.
After you enter the PlotterManager command in AutoCAD, it should open a Window that would contain a shortcut called Add-A-Plotter Wizard.
If it does not, you can always find the command located under the AutoCAD 2017 folder:
C:\Program Files\Autodesk\AutoCAD 2017\addplwiz.exe
If you don't see this file under the AutoCAD 2017 folder, then you should reinstall the program.
Paul Li
IT Specialist
@The Office
