paullimapa
en respuesta a: Anonymous
Again same as previous versions of AutoCAD.
After you enter the PlotterManager command in AutoCAD, it should open a Window that would contain a shortcut called Add-A-Plotter Wizard.
If it does not, you can always find the command located under the AutoCAD 2017 folder:
C:\Program Files\Autodesk\AutoCAD 2017\addplwiz.exe
If you don't see this file under the AutoCAD 2017 folder, then you should reinstall the program.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
