7353 Vistas, 10 Respuestas
How to create .EPS file from Autocad 2017
How to create .(eps) file from AutoCad 2017.
vladimir_michl
en respuesta a: Anonymous
You can use the PSOUT command to create .EPS from your drawing. See:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=1784
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
en respuesta a: vladimir_michl
When I apply PSOUT command it gives the following dialog box as attached.
it just saves all the drawing to .eps format, mean not giving any window option.
vladimir_michl
The Option dialog is under Tools>Options as the tip suggests.
when i create .eps file from _PSOUT command and import to adobe photoshop for rendering it is very light results as in attached images.
vladimir_michl
It is a matter of paper size, resolution and the default lineweights - we have extended the tip on how to handle lineweights.
john.vellek
Hi @Anonymous,
If you also use Illustrator, I have found the best workflow for me is to save the drawing to a version that your version of Illustrator can open and then open it there. Once open in Illustrator, getting it to work properly in Photoshop is a breeze.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @vladimir_michl's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
paullimapa
same way as previous versions of AutoCAD using the print command with EPS printer:
https://forums.autodesk.com/autodesk/attachments/autodesk/529/46771
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
en respuesta a: paullimapa
how is it possible in 2017?
add a plotter wizard.
paullimapa
Again same as previous versions of AutoCAD.
After you enter the PlotterManager command in AutoCAD, it should open a Window that would contain a shortcut called Add-A-Plotter Wizard.
If it does not, you can always find the command located under the AutoCAD 2017 folder:
C:\Program Files\Autodesk\AutoCAD 2017\addplwiz.exe
If you don't see this file under the AutoCAD 2017 folder, then you should reinstall the program.
Paul Li
IT Specialist
@The Office
