How to create a validation on a parameter in autocad
Hi Team,
I am new to AutoCAD. I want to know if there is any way to apply a validation or check on the drawing model that are being created using some templates containing some attributes in such a fashion that it will check if a particular attribute is having a value or not.If there is no value for that attribute then check-in should fail.
Swapnil Ballal
tramber
In your template, you can :
_dwgprops
in the last panel, create your own customized property. (mine is named okornot)
In the drawing area, you can insert a _FIELD containing the info.
It is an idea. Not needing too much effort, is it ?
And more : i beleive this can be done with both a mtext or an attribute definition...
tramber
@Anonymouswrote:If there is no value for that attribute then check-in should fail.
oops. I forgot this topic.
If a dwg or dwt is not allowed to open, how to open it in order to change this check-in value if not through a lisp program that would have to act externally ?
Or a question that would be asked at opening to change the value ? Well, better done with lisp again.
(this is why I prefered to talk about _dwgprops, easy to ask for values in programing as far as I remember)
