We are working on a project that has a 1:100 scale and want to convert to 1/8"=1'-0" scale.
Can anyone provide a scale conversion factor that has dealt with this before?
Hi Sherman,
1/8" * 96 = 1'0"
Dave
Dave Stoll
Las Vegas, Nevada
Here are some good reads:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
is your drawing 1 unit = 1mm or 1 unit = 1 meter
Surely the scale of the drawing does not matter.
It is the drawing unit size which is important.
As others are saying. Scale is irrelevant. It's just a ratio. You need to change the units from metric to imperial. Most likely mm to inches.
