How to convert CAD drawing from metrics to inches
Message 1 of 20
Greeting
Need help with converting the drawing from metrics to inches, and once drawing is completed - back from inches to metrics.
Thanks, Anthony
Accepted solutions (3)
Replies (19)
Message 2 of 20
Patchy
Use:
-DWGUNITS and choose YES to scale.
Message 3 of 20
Appreciated your help but after converted as mentioned, I copied / pasted in the drawing (inches setting) - the drawing didn't scale to the inches setting, further assistant, please.
Thanks, Anthony
Message 4 of 20
john.vellek
Hi @Anonymous,
-dwguinits or units will change the units in your drawing but they won't fix the scale discrepancy. To get everything to inches from metric, you will need to turn everything on, thaw everything and then unlock everything. Now you can scale the centimeter or millimeter based drawing by using SCALE. Then you will need to adjust your dimension and text styles accordingly.
Alternatively, you could simply XREF the file into a new master and scale it to the proper size.
Or, you can add your dimensions and dispaly alternate units - does this work for your project?
Please let me know if this makes sense or if you need additional help or resources.
John Vellek
Message 5 of 20
Thank you John.
Can you help provide step by step on the "scale process" and or "turn everything on"?
Message 6 of 20
john.vellek
HI @Anonymous,
I can do this step-by-step if you like but I found a video that might work better? Please let me know and I will jump back in if you like. You can also attach a sample drawing if you would like me to take a look.
John Vellek
Message 7 of 20
scot-65
No need to scale anything.
Background:
We had a client that required PDF's that show Metric units and we use Imperial.
Needed some way to be able to keep editing in Imperial, yet transmit showing in Metric.
What you will be changing a few dimension style variables, then applying to existing dimension objects.
Command -DIMSTYLE "Apply" and select everything (notice the hyphen "-" prefix in the command name).
You can set these variables as temporary overrides (by entering at the command prompt) or
apply these settings and saving the current dimension style.
Have a look (I have posted this panel quite a few times over the years...)
As you can see, there are four dimension variables to adjust. That's it.
And Welcome to these Forums.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 8 of 20
Alfred.NESWADBA
@john.vellek
Really?
I'm more with @Patchy
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 9 of 20
john.vellek
Hi @Alfred.NESWADBA,
Perhaps I am not understanding the question, but since AutoCAD works on a unit basis and doesn't really know what a cm or inch is I don't (IMHO) think that just changing units works the way the OP wants.
I made a Screencast to illustrate my understanding of this issue. I show that when I have imperial units configured in my dwg, I draw a 12 unit (1 foot) long line. Then I change the units to CM. now the line measures something different than 12 units.
Here is an article that also hopefully helps to explain my point of view.
Also, merely switching dimensions factors works only if you are dimensioning existing objects. Drawing new objects in a different units configuration can be a real pain.
John Vellek
Message 10 of 20
@john.vellek
attached is equipment in metrics and like convert into inches and copy / paste into inches CAD file.  Appreciated your help.
Message 11 of 20
john.vellek
Hi @Anonymous,
Does this work for you? I scaled all the contents by 0.0393701
John Vellek
Message 12 of 20
sorry - didn't work....when insert or copy over to the building drawing, scale is not correct.  See attached.
Message 13 of 20
john.vellek
HI @Anonymous,
I disagree! When I inserted the file I sent you it comes in correctly. Take a look in the upper right corner. I think this the correct size.
Let me know if this is wrong and we can try something else.
John Vellek
Message 14 of 20
you're correct, sorry.   Can you provide the step by step to you convert this?
Thanks a million!
Message 15 of 20
john.vellek
Hi @Anonymous,
Sure thing!
You had already changed the units to inches using -dwgunits/units so all that was left was to scale.
II checked to make sure that everything was turned on, thawed, and unlocked. Then I used SCALE, selected everything and applied the scale factor of 0.0393701
John Vellek
Message 16 of 20
thank you and how did you arrived with scale factor at 0.0393701?  2nd - if to scale drawing back to Metric (?), what is scale factor.
Message 17 of 20
john.vellek
Hi @Anonymous,
That is the easiest part of all of this - an online calculator 🙂
John Vellek
Message 18 of 20
Alfred.NESWADBA
Exactly, because 12 inch is not equal to 12cm, that's why you get a different value. At least the -DWGUNITS command can do that scale without needing to start scale, or using insertions from one drawing with units-setting 1 to another drawing with units-setting 2. All done in one step.
BTW: you don't need to know the scale factors between different units.
And even better: you don't loose accuracy because you can't type in the conversion factors to all decimal places 😉
- alfred -
Alfred NESWADBA
Message 19 of 20
john.vellek
I guess I have had it do screwy things so many times in the past (no doubt user error) that I quit using it for the longest time. I will have to re investigate the scale option in dwgunits to update my attitude.
Thanks as always for the contribution.
John Vellek
Message 20 of 20
RobDraw
Patchy nailed it in the first response.
Rob
