AutoCAD Forum
How to convert a mesh into a 3d solid for editing
2 REPLIES 2
cwebb46
242 Views, 2 Replies
I am having a hard time trying to convert a mesh into a 3d solid. Any suggestions on how to do so? I can't share the file due to confidentiality reasons.
2 REPLIES 2
Patchy
in reply to: cwebb46
AVCPlugins
It is important to understand that most of the polygonal models that you find on the Internet are not suitable for use in engineering design (CAD). The solid model obtained from them will be incredibly heavy and very inaccurate. The best way to convert is to re-model using the mesh only as snap points.
But if your mesh was once a solid-state model, then you can try converting it back. The mesh should be as simple as possible, not from millions of polygons, but from dozens. The mesh must be completely closed (waterproof). Then you can use ConvToSolid or the AVC MeshToSolid plugin.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
Forma Design Contest
