How to check the chord bearing of an arc?
How to check the chord bearing of an arc? Please help. Thanks!
cadffm
I don't understand what you like to do,
"to check"? Check what?
A picture/dwg whould be helpful to understand what you want and a more detailed description of what and what you want.
I know, this way is a really new creative idea, but i am sure it works well.
Sebastian
Patchy
FIELD
Kent1Cooper
@Patchy wrote:
FIELD
Not....
But you could draw a Line across the chord, and look at that, for which you wouldn't need a Field, but just the Properties palette or List command.  Set your angular Units setting to Surveyor's Units if that's the kind of "bearing" display you want.
Kent Cooper, AIA
Patchy
Arc Length or chord bearing to stake in the field?
Kent1Cooper
[Since that was in Reply to me, I note that you're asking the wrong person, but....]  Is the answer to that not clear from the Title wording and Message 1?  That is, the answer to whether they want the Arc length  or the chord bearing -- I don't see that it makes any difference whether or not it's for staking in the field.
Kent Cooper, AIA
