- Mute
- Permalink
- Report
I've currently run into a problem with 3D modelling
A customer build a step file from ProE, which is the attached file as below
I've managed to successfully import the file, everything works fine ... until I tried to edit it.
For beginner, I just started playing around with 3D modelling (in CAD) recently (mostly was doing in 2D in the past), so it would be nice if anyone can go abit of detail about the steps
Anyways, back to the subject. I am trying to edit the position of the holes, but whenever I tried to select the cylinder of space, it highlights the entire object.
I do have a little bit of experience with Maya, so I was thinking by converting the object into CVs, I can work with the edges/splines, but that doesn't seem to work.
So ... It'd be nice if anyone can give me a little handy tip on how to resolve this issue.
Thanks in advance 😄
