AutoCAD Forum
how to batch plot "plot to file" ?
6 REPLIES 6
yairMSKTU
309 Views, 6 Replies
batch plots works fine for the pdf, dwf and dwfx options.
but i also want to batch plot using the option "plot to file",   (where i work, this configuration creates .plt).
*i know in order to batch plot i need to set in advance all the plot settings before,  but autocad doesnt seem to remember the "plot to file" option.
6 REPLIES 6
cadffm
in reply to: yairMSKTU
>>"but autocad doesnt seem to remember the "plot to file" option"
Right, nothing to do with batchplot, this option is simply not part of a pagesetup.
But you can set up a plot configuration (.pc3) with "plot to file" is enabled!
Create/Edit .pc3 file, look at tab "General".
- Sebastian -
vlsheehan
Have you tried to create a Plot to PLT PC3 file to use in Publish?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
rkmcswain
Blast from the past. I was not aware anyone still printed HP-GL/2 plot files these days.
R.K. McSwain     | CADpanacea | on twitter
pendean
...*i know in order to batch plot i need to set in advance all the plot settings before,  but autocad doesnt seem to remember the "plot to file" option.
Not quite correct.
Basic PUBLISH tip for what you desire:PUBLISH RULE OF THUMB:
1. Launch Publish from a drawing that is not part of the publish set, but is configured with all your possible sheets and plotter options (like your plot to file choice).
2. Bring in all the other drawings/tabs to be published.
3. Import the pagesetup desired from the template file (in your case, one set up for exacting desired output).
4. PUBLISH.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Selecting-one-page...
yairMSKTU
in reply to: vlsheehan
im well aware where im from the government never heard of "advancement" in civil engineering.
yairMSKTU
in reply to: cadffm
thanks, that fixed the problem.
Autodesk Customer Advisory Groups
